List in my Watch node is not same as my schedule
I am trying to get new rebar numbers with Dynamo -Revit. The new rebar numbers are placed in that way so first the rebars are sorted first by parameter “Shape” , then by “Bar Diameter” and at the end by parameter “Bar Length” . The sorting by the parameters “Bar Diameter” and “Bar Length” are working fine , but the sorting by the parameter “Shape” is not good .
This is mine Dynamograph (1pic) for the parameter ‘‘Shape’’ .It connects to the Python script node (2pic) IN[0].Also have 2 more parameters “Bar Length” and “Bar Diameter” conected to IN[1] and IN[2]. I get new unique rebar numbers base on this code :
dataEnteringNode = IN
# Input rebar lists and parameters
rebars_list1 = IN[0]
rebars_list2 = IN[1]
rebars_list3 = IN[2]
parameterName = IN[3]
starting_number = IN[4]
# Helper function to safely get parameter values and convert them to comparable types
def get_parameter_value(rebar, param_name, default_value=None):
    value = rebar.GetParameterValueByName(param_name)
    if value is None:
        return default_value
    try:
        # Attempt to convert to float if possible
        return float(value)
    except (ValueError, TypeError):
        # If conversion fails, return as string
        return str(value)
# Group rebars in rebars_list3 by "Bar Length" and "Bar Diameter"
length_diameter_grouped_rebars = {}
for rebar in rebars_list3:
    length = get_parameter_value(rebar, "Bar Length", 0)
    diameter = get_parameter_value(rebar, "Bar Diameter", 0)
    key = (length, diameter)
    if key not in length_diameter_grouped_rebars:
        length_diameter_grouped_rebars[key] = []
    length_diameter_grouped_rebars[key].append(rebar)
# Print the initial groupings for debugging
print("Initial groupings:")
for key, group in length_diameter_grouped_rebars.items():
    print(f"Key: {key}, Group Size: {len(group)}")
# Flatten the grouped rebars while maintaining order within each length-diameter group
grouped_rebars_list3 = []
for key in sorted(length_diameter_grouped_rebars.keys()):
    grouped_rebars_list3.extend(length_diameter_grouped_rebars[key])
# Combine all rebar lists into one in the specified order
all_rebars = rebars_list1 + rebars_list2 + grouped_rebars_list3
# Sort the combined list by "Shape" first, then "Bar Diameter", and then "Bar Length"
sorted_rebars = sorted(all_rebars, key=lambda rebar: (
    get_parameter_value(rebar, "Shape", ""),
    get_parameter_value(rebar, "Bar Diameter", 0),
# Print the sorted list for debugging
print("Sorted rebars:")
for rebar in sorted_rebars:
    shape = get_parameter_value(rebar, "Shape", "")
    print(f"Shape: {shape}, Diameter: {diameter}, Length: {length}")
# Initialize parameters for numbering
numberMap = {}
current_number = starting_number
# Assign unique numbers to rebars based on length and diameter grouping
    if key in numberMap:
        rebar.SetParameterByName(parameterName, numberMap[key])
        numberMap[key] = current_number
        rebar.SetParameterByName(parameterName, current_number)
        current_number += 1
    # Print debugging information
    print(f"Rebar: {rebar}, Length: {length}, Diameter: {diameter}, Number: {numberMap[key]}")
# Output the last assigned number
OUT = current_number - 1
why there is no sorting based on the parameter ‘‘Shape’’?? Do I need modify code or to do new Dynamogrph with different nodes?
MOD EDIT: formatted code
@bojans.new
can you use
grafik
for pasting your code
are you shure the code is right, you use print - in dynamo works only print.
# code </>
When sharing screenshots it’s always best to pin the node preview bubbles so we can see what your data looks like and how its structure is being handled.
allRebars = IN[0]
partition = IN[1]
rebars = []
for rebar in allRebars:
    if rebar.GetParameterValueByName("Partition") == partition:
        rebars.append(rebar)
OUT = rebars
Your graph looks correct. Can you show us the sorting/grouping settings from the schedule? It certainly doesn’t look like it’s being sorted by Shape only.
