I’ve come across this several times. It usually happens when using jagged lists (i.e. lists of lists). Using Dynamo 0.8.0.950
As an example see: http://dynamobim.com/forums/topic/building-lists-of-lists-from-other-lists-of-lists/
I’m referring to the way the AddToEnd node works through the List.Combine. I.e. in this sample:
I mean it seems as if there’s an automatic List.Map applied to the first item. I.e. the above is actually doing this:
So I’m guessing that Dynamo automatically applies a map to the panes where possible. But, if that’s so, then why does it not work when I try to do the same thing using AddToFront?
I mean, it’s not as if there’s actually anything different between the 1st and the 3rd items - just the position into which it should add.
Is there some rule-of-thumb one can apply concerning when this automatic mapping happens and when it doesn’t? Or should one just do some trial-n-error until it works as you expected?
