List Create (With Strings)
Can your python code [1] also work with strings? @c.poupin
import sys
lst = IN[0]
def splitBySequence(lst):
	if lst:
		grouplst = [lst.pop(0)]
		for i in lst:
			if i -1 == grouplst[-1]:
				grouplst.append(i)
		lst = [i for i in lst if i not in grouplst]
		return [grouplst] + splitBySequence(lst)
		return []
OUT = splitBySequence(lst)
strings test.dyn (14.8 KB)
[Ref 1]
That’s just not how strings work. Try converting the string to a number to compare and then convert back.
Works perfectly with what @Nick_Boyts suggested.
lst = map(lambda x: ord(x), IN[0])
	if lst:
		for i in lst:
				grouplst.append(i)
		return []
OUT = map(lambda y: [chr(x) for x in y], splitBySequence(lst))
