Links ManageWorkset parameters
hi dears,
is there a way to get the values for the link worksets if it is opened or closed ?
Hi @khuzaimah.ElecEng,
Yes it is possible. (UserWorkset.IsOpen property in the API)
thanks @Alban_de_Chasteigner
that is exactly what I want
if I want to get this data to set them to another links , to be the same
do you have a Node for that ?
There is a method to close worksets when you open a revit document but I can’t find a node for that.
thanks, I will try to write a python script for it, am not professional in that , but I will try
