i using Python to Link revit file but iam facing the below problem , the link is there but actually doesn’t exist as geometry in the current file.
Script:
Import ToDSType(bool) extension method
Import geometry conversion extension methods
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
clr.AddReference(‘DSCoreNodes’)
import DSCore
from DSCore.List import *
import System
import sys
pyt_path= r"c:\program Files (x86)\ironPython 2.7\lib"
sys.path.append(pyt_path)
import math
app = uiapp.Application
pathName = IN[0]
path = Autodesk.Revit.DB.FilePath(pathName)
Start Transaction
options = Autodesk.Revit.DB.RevitLinkOptions(True)
Autodesk.Revit.DB.RevitLinkType.Create(doc, path, options)
#RevitLinkLoadResult.Create(Autodesk.Revit.DB.Document,path,options)
#End the Transaction
doc.Regenerate()
OUT = dir(options)
