I have made a simple script I would like to make more power. Here is my current work.
What this is being used for it selecting a wall element and then have it provide how wide the wall is and this parameter is used to set the width of an angle that is hosted to it. What I would like to have this do is select multiple walls and then have it apply the adjustment if needed for all selected walls and corresponding angle selected. For now when I try and select more then one wall it dose not change all the angles. I have even selected the walls and angles in the exact same order to make sure the right parameter is used.
