Linked Element Location Co Ordinates
I Need Custom Nodes to Get The Linked Elements Co Ordinates For Multiplie Site Can Anyone Prefer anything for me
@ahmedabdlsalamm ,
that can be a starting point
clr.AddReference('RevitAPI')
links =  FilteredElementCollector(doc).OfClass(RevitLinkInstance)
output = []
for i in links:
	doclink = i.GetLinkDocument()
	collector = FilteredElementCollector(doclink).OfCategory(BuiltInCategory.OST_GenericModel)
	all_elements = collector.WhereElementIsNotElementType().ToElements()
	output.append(collector)
OUT = output
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('System')
#functions
def tolist(x):
    if hasattr(x,'__iter__'): return x
    else: return [x]
elements = UnwrapElement(tolist(IN[0]))
output = []
for i in elements:
	output.append(i.Location.Point.ToPoint())
OUT = output
grafik
KR
Andreas
Hi @ahmedabdlsalamm is it something here you look after ?
Revit_zPrmzYDbC0
yes i want something like that but i need to get location for more than one shared site
you can only have one active site at time, but you can just change you site and get your linked elements location from that site, relative or absolut
i want to get this all Shared Site Location for this links
@ahmedabdlsalamm ,
thats a other issue… i understand
You could try export these site location…
Revit_qeE7WdxlO1
I’m not sure if I answer the request exactly, but here is a workflow with python
import sys
import System
#import Revit API
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
rvtLinkInstance = UnwrapElement(IN[0])
lnkDoc = rvtLinkInstance.GetLinkDocument()
lenghtUnit = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
angleUnit = doc.GetUnits().GetFormatOptions(SpecTypeId.Angle).GetUnitTypeId()
projLocation = next((p for p in lnkDoc.ProjectLocations if p.Name in rvtLinkInstance.Name), None)
if projLocation:
    projPosition =  projLocation.GetProjectPosition(XYZ.Zero)
    angle = UnitUtils.ConvertFromInternalUnits(projPosition.Angle, angleUnit)
    east_west = UnitUtils.ConvertFromInternalUnits(projPosition.EastWest, lenghtUnit)
    north_south = UnitUtils.ConvertFromInternalUnits(projPosition.NorthSouth, lenghtUnit)
    elevation = UnitUtils.ConvertFromInternalUnits(projPosition.Elevation, lenghtUnit)
    OUT = rvtLinkInstance.Name, f"angle : {angle}", f"east_west : {east_west}",  f"north_south : {north_south}",  f"elevation : {elevation}"
Hi, I have a question related with UI Script.
When I was run a script the UI will appears on my screen to enter the first input and press set values. the UI will be hide to export data to excel and I will run script again to enter the second input and so.
Is there a way to keep a UI script on my screen
To enter first input and run to export data then enter second input and run to export data without the UI will be hide every time.
Hi not with datashapes
