Line to rotate at same direction from plane
Tangent to Circles.dyn (27.8 KB)
Hi All
I’m trying to rotate lines radiating from the center of a circle in the same direction from the horizontal plane. For some reason they currently rotate in opposite directions. Please see images and dynamo file attached.
Thanks for your help in advance.
Try reconstructing your graph to use consistent Vectors then rotate.
Large Image
there is this example also
LineDir.dyn (34.6 KB)
WOW thanks for the response! Will look through and get back to you!
Thank you so much. I’ll look through. Much appreciated.
