'Line' object has no attribute 'ToProtoType'
The Primer says this should work:
What am I doing wrong?
It works fine without the ProtoType thing, but I cannot make any sense of it in Dynamo:
Believe you are missing the geometry conversion part of the boilerplate code.
Hi Danail,
To use ToProtoType add above :
Because you only imported the Element wrapper extension methods and not the geometry conversion extension methods.
Thank you both, Alban and Jacob!
Here’s the final code, to whom it may be useful in the future:
import sys
clr.AddReference('RevitAPI')
areas = UnwrapElement(IN[0])
curveslist = []
Options = SpatialElementBoundaryOptions()
Options.SpatialElementBoundaryLocation = SpatialElementBoundaryLocation.Center
for area in areas:
	curvesSublist = []
	for curve in area.GetBoundarySegments(Options)[0]:
		curvesSublist.append(curve.GetCurve().ToProtoType())
	curveslist.append(curvesSublist)
OUT = curveslist
