easy one.
How to generate two series of lines connection 2 points translated along Z…
Basically the blue lines I sketched.
Simone
Well, I think I got lost
too much for my level still.
I was looking for soething easier (i guess), basically just connecting points that will be coping in vertical. So the results would be 5 lines (vertical and straight), per starting point.
The idea is then to assing a Revit column type to them.
Hope I was clear,
Thanks a lot!
This:
This is ultra simple, plus you can add as many origin points as you like to the List.Create node and it will simply generate more line stacks
@simoneavellini Here is another possible way.
