Hi All,
Just wondering can we create a straight line and Arc with radius from mutiple PVI points using Dynamo. As seen in bellow image. Hope i am not missing any bestfit lines or Arc nodes.
The purpose of this exercise is to create a combination line and arc on a polyline with multiple PVI points. for example say survey points which are not exactly in same line will have small deviations but can be created in to a single line or ARC by joining the points.
Wishing all a happy holidays and thanks for support.
Have you tried one of these?
@jostein_olsen Thanks for reply …which package it is ? Can i use these nodes for AutoCAD ?
I think so, as stated above the nodes. two from springs package and one comes out of the box in Dynamo, meaning it is in the standard library
Thanks alot …will try using them and see if it works.
tried installing package …got bellow error. seems its not compatible with AutoCAD API.
Hi. @shahid.shaikh_C3D did you find the solution for this?
I am trying to eliminate vertices on polyline,
- It needs to combine all the arcs which is split into multiple
2.it needs to remove the vertices/combine lines which is split into multiple.
Hi @aravind.akhil007. I have not found any solution and feels this is not possible though dynamo
Might be a good case for generative design as connecting point and creating line/arc will have many solutions.
