Hi All,
New to Dynamo and learning as I go. This is a simple one. I would like to schedule the elevation of wall lights by means of using the built-in Revit Elevation Parameter and then write the values into a schedule where I create a new parameter called “ELE”. (I used wall lights as they have elevation offsets)…
What logic am I missing so simply read built-in parameters and then write it back to a schedule parameter?
Thank you in advance!
DYN_Lighting_Fixture_Elevations.dyn (5.7 KB)
