Level elevation node / getset descripter not callable
Hi all,
Im getting an error when Im using the node to read the elevation of a node in a python script.
When I use it in a regular Dynamo node it does work but in a python script it gives me the error ‘getset descripter not callable’
Can someone maybe see what I`m missing?
Regards,
Wouter Hilhorst
Hi @wouter.hilhorst,
You have to unwrap the levels.
Unwrapping
Elevation is a property and doesn’t need parentheses (which are for methods).
clr.AddReference('RevitAPI')
V2 = UnwrapElement(IN[3])
V3=[]
for itm in V2:
	temp=itm.Elevation
	V3.append(temp)
OUT = V3
@wouter.hilhorst
Probably there is a conflict with two namespace and Class Dynamo API and Revit API in your code
Level.Elevation() it’s a Dynamo API method
Thanks!
