Summary
I was trying to get building footprints’ points from latitude longitude to cartesian coordinates in the last forum post. Since then, I have been trying to get all building’s footprints and after I am planning to extrude the building footprints.
Last Code creating the list in the "Autodesk.DB.XYZ list" format
from math import cos, sin
clr.AddReference("RevitAPI")
def ll2cc(lat, lon, deg=True):
def rad(d):
return UnitUtils.Convert(d, UnitTypeId.Degrees, UnitTypeId.Radians)
R = 63710088 # Arithmetic mean radius of Earth in meters
if deg:
lat, lon = rad(lat), rad(lon)
return XYZ(R * cos(lat) * cos(lon), R * cos(lat) * sin(lon), 0)
loc = doc.SiteLocation # Site Location
lat = loc.Latitude
lon = loc.Longitude
# Translate site location lat, lon to 0, 0
translation = XYZ.Zero.Subtract(ll2cc(lat, lon, False))
transform = Transform.CreateTranslation(translation)
latlons = IN[0] # List of lat lon pairs in degrees
OUT = [transform.OfPoint(ll2cc(*ll)) for ll in latlons]
Q1: How can I get a structured list from that code?
The first issue I have encountered is: that the levels of the list are 5 and I can’t run a Python script on that list to make every building’s point translation to cartesian coordinates. I can only translate 1 building’s coordinates.
I want to list structure stay cause each building’s footprint points need to stay separately for further steps (extruding them according to heights).
I tried this:
1. I was getting coordinates data from a code block written this “get_data_values[ x ] [ “geometry” ] [ " coordinates " ];”
2. Then, I get L2 data structure from a code block written this “get_data_value[ 0 ] [ 0 ]; " coordinates " ];” which resulted me getting only 1.building’s footprint points.
3. Then, I thought to get all buildings footprint coordinates in L2 data structure, I should create a code block written this "get_data_value[ 0 ] [ x ] [ 0 ]; " which resulted me getting only 1.building’s footprint points again.
I need to learn level structure more precisely I guess. I have searched for level structure from here But I couldn’t learn much.
I also tried changing the coordination translation code into this
I tried adding a line that creates a list appending all results in the code
# Place your code below this line
def rad(d):
if deg:
lat = loc.Latitude
lon = loc.Longitude
**# These lines are added.**
**transformed_points = []**
**for ll in latlons:**
** transformed_points.append(transform.OfPoint(ll2cc(*ll)))**
OUT = transformed_points
Q2: How can I get a polygon or polyline from that list? - (I have a height list also to extrude them in the future.)
My second issue is to create a polyline or polygon out of XYZ result.
From this result, polygon and polyline can’t be created. the error is saying that the list is Autodesk.DB.XYZ[.] not Autodesk.DesignScript.GeometryPoint[.], that is why it can’t create a polygon or polyline.
I exported them to csv and saw the point structure.
To get x,y,z points from the list I tried to split the list this way. But I get null result.
code
import sys
latlonlist = IN[0]
def split (latlonlist):
split_items = (i.split(',') for i in latlonlist)
OUT = split(latlonlist)
How can I split them into x,y,z to create a polygon or is there a way to create a polygon from the last code giving me this result list Autodesk.DB.XYZ[.]
