Hello All,
I am quite new to Dynamo. I developed a script using a tutorial. The structural columns join to walls on smaller projects, but Revit hangs when I use the same script for larger projects.
Can someone please help identify any missing steps for larger projects?
Package used: Clockwork
@Lolu.Ak ,
than you have to cluster your task
f.e. by View
by Level
by Walltype
or prefilter them do they even intersect … a.s.o.
KR
Andreas
Thank you @Draxl_Andreas
I already tried by view. Revit still hung.
Are you suggesting I add view, level, wall type all in the same script?
It took some time but it worked. Columns and walls joined.
I have 2 questions:
- There seems to be an error/warning. Will this affect the floor plan of the project?
- The walls and columns on all floors have turned to blue color in plan and 3D. Is there a way to make them black?
