Hello, I’ve got some issues when extracting the material density parameters. The topic has alredy been discussed but, coding the same as the proposed solution, I still get a false result and I can’t figure out what is w
rong.don’t flatten fully, you need to change the list level
Oh okay I got it, but do you know when I have an empty list, because the density was not defined ( or in general the material has no physical oder thermal asset) how to instead of skipping the result, a 0 is being inserted or at least the field is left blank? Because here for example I have 5185 materials but only 1824 densities as a result
If everything is well defined, then it works!
