Tried Filtering out the elements based on system abbreviation and then tried to isolate temporarily, but I couldn’t.
Let me know if anyone could lend me some help ?
You need to add a filter to the element list, so far you have only retrieved the values. Look into adding a list.filterbyboolmask node which feeds into the isolate in view node. The list should be the output of the all elements of category node. The bool input needs to be a true/false based on a comparison - say if the parameter value is equal to TBD return true. If not return false.
Look into the dynamo primer if you’re stuck with making booleans.
Hi Jacob,
Made some progress, ignore previous img,
Issue still persist, ?Isolate_Elements_Test-2.dyn (17.8 KB)
