ISelectionFilter in Python Script not working on RVT2023/CPython3 but working on RVT2021/IronPhyton 2
Hi!
Why this script is not working on CPython3? Any workaround?
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI.Selection import *
app = uiapp.Application
class MySelectionFilter(ISelectionFilter):
	def __init__(self):
		pass
	def AllowElement(self, element):
		if element.Category.Name == "Walls":
			return True
			return False
	def AllowReference(self, element):
		return False
selection_filter = MySelectionFilter()
walls = uidoc.Selection.PickElementsByRectangle(selection_filter)
OUT = walls
No work arounds I’m afraid, ISelection doesn’t work in CPython3… All you can do is find another selection method / use another coding language. Hopefully the shift to PythonNet3 will fix them.
Mark
What another coding language do you suggest? Is it possible to do inside Dynamo?
Hey,
I believe the recommended solution is to build a Zero-Touch node using C sharp, it is still possible to install IronPython2.7 but that is not recommended due to security concerns. The Dynamo roadmap has better integration as ‘under consideration’ Roadmap - Dynamo BIM feel free to add to the voices raising this as a priority.
Apologies for not having a better suggestion :frowning:
Mark
Ok! Thanks a lot @Mark.Ackerley!
Ironpython3 can be an solution too
