How to Enable ISelection filter in CPython3
Hello Dynamites!
Happy new year 2025
I’m facing some issues with the CPython while I’m using the Iselection filter. I have been using the same code in ironPython2 and its perfectly working fine. But there’s a challenge in CPython3 for which I would require your assistance in resolving the issues.
Error Message:
**Warning: TypeError : interface takes exactly one argument **
[’ File “”, line 48, in \n’]
Below I have attached the code & error message for reference
import sys
sys.path.append('C:\Program Files\IronPython 3.4\Lib')
clr.AddReference('System')
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
app = uiapp.Application
def tolist(obj1):
    if hasattr(obj1, "__iter__") : return obj1
    else: return [obj1]
run = IN[0]
if run:
	class DuctSelFilter(ISelectionFilter):
	    def AllowElement(self, elm):
	        if elm.Category.Name == "Ducts":
	            return True
	            return False
	filter = DuctSelFilter()
	pick = uidoc.Selection.PickObjects(ObjectType.Element,filter, "Select Duct Elements")
	outputElms = []
	for elm in pick:
	    outputElms.append(doc.GetElement(elm.ElementId))
	OUT = outputElms
	OUT = "Toggle Run button"
you have all the explanations in this post concerning your problem
cordially
christian.stan
Here is a solution (work on all Revit version except 2024)
For more information, see my blog post
import sys
def tolist(obj1):
    else: return [obj1]
run = IN[0]
if run:
    class Custom_SelectionElem:
        def __new__(cls, *args, **kwargs):
            cls.args = args
            # name of namespace : "CustomNameSpace" + "_" + shortUUID (8 characters)
            # IMPORTANT NOTE Each time you modify this class, you must change the namesapce name.
            cls.__namespace__ = "Custom_SelectionElem_tEfYX0DHE"
            try:
                module_type = __import__(cls.__namespace__)
                return module_type._Custom_SelectionElem(*cls.args)
            except ImportError as ex:
                print(ex)
                class _Custom_SelectionElem(ISelectionFilter):
                    __namespace__ = cls.__namespace__
                    def __init__(self, bic):
                        super().__init__()
                        self.bic = bic
                    def AllowElement(self, e):
                        if e.Category.Id == ElementId(self.bic):
                            return True
                            return False
                    def AllowReference(self, ref, point):
                        return True
                return _Custom_SelectionElem(*cls.args)
    filter = Custom_SelectionElem(BuiltInCategory.OST_DuctCurves)
    refs = uidoc.Selection.PickObjects(ObjectType.Element,filter, "Select Duct Elements")
    OUT = [doc.GetElement(ref) for ref in refs]
Got it, Thank you :+1:
although its temporary, for the time being it helps. Thanks @c.poupin
