Is there a way to use the External Document Notes from the Camber Package (or any nodes for that matter) to attach an xref file to a drawing? Would be similar to what I show below, but rather than using the current document I would like to use external document. Reason for the graph would be to expedite attaching an xref file to a bunch of DWGs without having to open them up individually.
Hi @hestingjj,
I think you can do this with just a small shift in your perspective. Rather than using a single Dynamo graph to modify multiple other DWGs concurrently, you can create a graph that works with the active DWG and then run that graph separately in multiple DWGs. You can do that part with the Batch Save Utility, as discussed here:
