Hello, is there any node similar to PVIandRadius or do you have maybe the Python code to use it momentarily civil 3d 2025?
@zachri.jensen and @hosneyalaa Please could you help me with this?
I’m not trying this before
Try AddFreeCircularCurveByPVIAndRadius Method by python code
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=fee99593-3c87-5093-dec2-464e116b603f
Can anyone help with the code in CPython?
Example.dyn (88.7 KB)
Intro-1.dwg (2.4 MB)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
import Autodesk.Civil.DatabaseServices as civdbs
dataEnteringNode = IN
# Get the active document
editor = adoc.Editor
civdoc = CivilApplication.ActiveDocument
# Input parameters
profile = IN[0] # Profile object
attach_point = IN[1] # PVI index to attach the curve
curve_length = IN[2] # Length of the circular curve
def AddFreeCircularCurve(profile, attach_point, curve_length):
with adoc.LockDocument():
with adoc.Database as db:
try:
# Get the profile object
profileId = profile.InternalObjectId
profileObj = t.GetObject(profileId, OpenMode.ForWrite)
# Get PVIs collection
pvis = profileObj.PVIs
if attach_point >= pvis.Count - 1:
raise Exception("Attach point must be less than the total number of PVIs")
# Get the PVI points we'll work with
pvi1 = pvis.GetPVIAt(attach_point)
pvi2 = pvis.GetPVIAt(attach_point + 1)
# Calculate grade between points
grade = (pvi2.Elevation - pvi1.Elevation) / (pvi2.Station - pvi1.Station)
# Calculate curve parameters
halfLength = curve_length / 2.0
startStation = pvi1.Station + halfLength
endStation = pvi2.Station - halfLength
# Add the circular curve
curveParams = civdbs.ProfileCurveParameters()
curveParams.CurveType = civdbs.ProfileCurveType.Parabolic
curveParams.Length = curve_length
profileObj.AddVerticalCurve(attach_point, curveParams)
t.Commit()
return profileObj
except Exception as ex:
editor.WriteMessage("\nError: " + str(ex))
return None
# Execute the function
result = AddFreeCircularCurve(profile, attach_point, curve_length)
# Assign your output to the OUT variable
OUT = result
any ideas regarding this please
@hosneyalaa
@zachri.jensen
@Anton_Huizinga
import sys
# Input parameters
try:
# Get the PVI to attach the curve to
attachPVI = pvis.GetPVIAt(attach_point)
# Add the circular curve using the correct method
curve = profileObj.AddFreeCircularCurveByPVIAndLength(attachPVI, curve_length)
t.Commit()
return profileObj
return None
OUT = result
I can’t get it to work
TRY
profileObj.Entities.AddFreeCircularCurveByPVIAndLength(attachPVI, curve_length)
t.Commit()
return profileObj
I have tried but it still does not work
I find it incredible that with the number of experts on this forum, no one is able to give you an answer. Great work, I’m trying to fix the error, but I can’t seem to…
PPEE_Alignment_ONLY_DesingProf_v1.dyn (137.6 KB)
import sys
from Autodesk.AutoCAD.Runtime import Exception as AcadException, ErrorStatus
profile_lists = IN[0] # Lista de perfiles
attach_points_lists = IN[1] # Lista de listas de PVIs (estaciones y elevaciones)
curve_length = IN[2] # Longitud de las curvas circulares
def find_pvi_index(profileObj, target_station, target_elevation):
"""Buscar el índice del PVI basado en estación y elevación."""
for idx in range(pvis.Count):
pvi = pvis[idx]
if abs(pvi.Station - target_station) < 1e-3 and abs(pvi.Elevation - target_elevation) < 1e-3:
return idx
return None
def AddFreeCircularCurve(profile, pvi_point, curve_length):
db = adoc.Database
try:
if hasattr(profile, 'InternalObjectId'):
profileId = profile
editor.WriteMessage("\nDEBUG: Procesando profileId = {0}".format(profileId))
if pvis.Count < 3:
editor.WriteMessage("\nADVERTENCIA: Perfil con menos de 3 PVIs, no se agregan curvas.")
return None
# Acceder a las propiedades estación y elevación del attach_point
target_station = pvi_point.Station
target_elevation = pvi_point.Elevation
idx = find_pvi_index(profileObj, target_station, target_elevation)
if idx is None:
editor.WriteMessage("\nERROR: No se encontró el PVI con estación {0} elevación {1}".format(target_station, target_elevation))
return None
if idx == 0 or idx == pvis.Count - 1:
editor.WriteMessage("\nADVERTENCIA: No se puede colocar curva en primer o último PVI. Se omite.")
return None
pvi_to_attach = pvis[idx]
editor.WriteMessage("\nDEBUG: Adjuntando curva en idx={0}, estación={1}, elevación={2}".format(idx, pvi_to_attach.Station, pvi_to_attach.Elevation))
# Insertar la curva
profileObj.Entities.AddFreeCircularCurveByPVIAndLength(pvi_to_attach, curve_length)
t.Commit()
return profileObj
editor.WriteMessage("\n[AddFreeCircularCurve] Error: {0}\n".format(ex))
return None
results = []
# Procesar todos los perfiles
for profile_list, attach_points_list in zip(profile_lists, attach_points_lists):
for profile, attach_points in zip(profile_list, attach_points_list):
for pvi_point in attach_points:
result = AddFreeCircularCurve(profile, pvi_point, curve_length)
results.append(result)
OUT = results
@manuel.lozanomASTWU could you fix it for civil 2025, I tried with the code you left but it doesn’t work.
I use this code for multiple profiles at my regular job, in version 2025.1. I just wanted to show you the way
Example (1).dyn (25.1 KB)
Maybe it’s my mistake but in civil 2025 the code does not work.
The file I am using as a test is the same as the one I attached in my previous posts
Sorry a
I’m not a expert. It’s civil 3d 2025 but with my code in your dwg… just wanted to show you the way
Blockquote
