Is it possible to know if a family in a project is shared?
Hi all,
I need to select families that are shared families. Is it possible to do that with dynamo or python?
Input - a list with a number of families
Output - boolean with the ones that are shared families.
Thank you!
Hello
a solution with GetSubComponentIds() method
EDIT : oups! Corrected code
clr.AddReference('RevitAPI')
flatten = lambda l: [item for sublist in l for item in sublist]
toList = lambda x : x if hasattr(x, "__iter__") else [ x ]
elems = toList(UnwrapElement(IN[0]))
lstSharedId = flatten([e.GetSubComponentIds() for e in elems ])
outBoolCheck = []
for e in elems:
	if e.Id in lstSharedId:
		outBoolCheck.append(True)
		outBoolCheck.append(False)
OUT = outBoolCheck
Try the following code to get only the families out that have shared parameter ticked
#Created By Brendan Cassidy
# Import RevitAPI
clr.AddReference("RevitAPI")
output=[]
#May need to change IN[0] to UnwrapElement(IN[0])
for a in IN[0]:
	for b in a.Family.Parameters:
		if b.Name == "Shared":
			if b.Value == 1:
				output.append(a)
OUT = output
Thanks both for your help!!
Is it possible to tick the shared parameter box through Dynamo?
