I’m trying to create a multi-selection list in Revit but haven’t managed to get anything working. I tried Data-Shapes but it doesn’t work with Revit 2022/cpython. Same with UI++. Is it possible?
Thanks.
Thanks.
Hi, if you share your script or script image we can able to see what is issue with that.
I believe Data-Shapes needs the IronPython package installed. You’ll find most custom packages will have same issue with Revit 2023 onwards if it isn’t installed.
If not, check out this thread here where winforms are being discussed:
