Is it possible to change flat wall into curved wall?
I want to edit profile of curved walls in revit without "Attach Top/Base” feature, but it seems impossible. So I wonder if I can edit profile in flat wall and change it into curved by dynamo. Is it seems possible? If it is, is there any node can help with?
In short: No you cannot edit the profile of a curves wall like you can do with a straight wall. Also you cannot make a straight profiled wall curved.
But there are other options to make profiled curved walls in Revit. On of them is indeed Attach top/base.
Another is to use a model inplace and make a void extrusion through the wall with the desired profile and cut in while in editing mode.
Sadly both options are not possible in Dynamo I think
BUT
You can do something else. You can create a Solid in Dynamo which goes through you wall, simulating the “Cut”. You can make a solid family out of this with dynamo and join in with all the curves walls that need to be cut. If you supply a sub-category to it you can turn this Solid Family off in the visibily graphics. See pics below
“Solid placed with Dynamo”
“Solid joined with curves wall”
“Script”
“Turn off VG sub category”
@Joelmick …damn a sneeky way :grinning:
Works better then I expected actually
““Join Elements Python Code””
#Import the Revit Services
#Import the Revit Nodes
# Import geometry conversion extension methods
#Import the Revit API
clr.AddReference("RevitAPI")
#Define tolist function
def tolist(obj1):
	if hasattr(obj1,"__iter__"):
		return obj1
		return [obj1]
#Define Input (IN)
elements = tolist(UnwrapElement(IN[0]))
cuttingElements = tolist(UnwrapElement(IN[1]))
output = []
# Start Transaction
for element in elements:
	for cuttingElement in cuttingElements:
		try:
			JoinGeometryUtils.JoinGeometry(doc, element, cuttingElement)
			#output.append(element.Name + " is joined with " cuttingElement.Name)
			output.append(element.Name.ToString() + " is joined with " + cuttingElement.Name.ToString())
		except:
			#output.append(element.Name + " is NOT joined with " cuttingElement.Name)
			output.append(element.Name.ToString()+ " is joined with " + cuttingElement.Name.ToString())
#End Transaction
#Define Output (OUT)
OUT = output
““Regenerate SubCategories Python Code””
clr.AddReference('System')
clr.AddReference("System.IO")
clr.AddReference("System.Collections")
from System import *
from System.Reflection import *
from System.IO import *
#Use elemIds = List[ElementId](ids) for ICollection(ElementId)
app = uiapp.Application
#Import math functions
import math
#GetInternalParameter
def GetInternalProperty(obj, propertyName):
	type = obj.GetType()
	property = type.GetProperty(propertyName, BindingFlags.NonPublic | BindingFlags.Instance)
	value = property.GetValue(obj)
	return value
#Define Input (IN)
cat = GetInternalProperty(IN[0], "InternalCategory")
output = []
materials = dict()
# Start Transaction
dummyMaterial = FilteredElementCollector(doc).OfClass(Material).ToElements()[0]
for sub in cat.SubCategories:
	subMaterial = sub.Material
	subName = sub.Name
	if subMaterial != None:
		materials.Add(subName, subMaterial)
		sub.Material = dummyMaterial
doc.Regenerate()
	subName = sub.Name
		material = materials[subName]
		sub.Material = material
#End Transaction
OUT = materials.Values
Thank you very much! I’ll try it!
