Is forbidden during iterating
is forbidden during iterating
Try removing the ā€˜sizes’ input from the call, as the method appears to only require two inputs - the standard name and the diameter.
Also, you have to call RemoveSizes on the ConduitSizeSettings instance not the type:
sizes.RemoveSizes(…
:smiling_face_with_tear: :smiling_face_with_tear:
still have same problem
import sys
sys.path.append(ā€˜C:\Program Files (x86)\IronPython 2.7\Lib’)
import System
clr.AddReference(ā€˜RevitNodes’)
clr.AddReference(ā€˜RevitServices’)
clr.AddReference(ā€˜RevitAPI’)
clr.AddReference(ā€˜RevitAPIUI’)
import System
from System.Collections.Generic import Dictionary
app = uiapp.Application
sizetype =
nomsize =
outsize =
sizetype =
list =
sizes =Autodesk.Revit.DB.Electrical.ConduitSizeSettings.GetConduitSizeSettings(doc)
x=
#OUT = dir(sizes)
Autodesk.Revit.DB.Electrical.ConduitSizeSettings.GetConduitSizeSettings(doc).RemoveSize(ā€œeeeeā€,16)
