Hi everyone, I am trying to find intersection between references of a column and a detail line using a Python script. tried everything, If anyone could help, it would be much appreciated. thenks
Hi @neria.Azriel and welcome !
are you tried this method ?
Hi, thanks for the welcome. I am really new to working in this environment. I would like to know if all the methods here can be used in Daynamo Python node?
Here is an example:
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
clr.ImportExtensions(Revit.GeometryReferences)
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
wall = UnwrapElement(IN[0])
cable_tray = UnwrapElement(IN[1])
ref_face = DB.HostObjectUtils.GetSideFaces(wall, ShellLayerType.Interior)[0]
face = wall.GetGeometryObjectFromReference(ref_face)
out_InterResultArray = IntersectionResultArray()
set_ComparisonResult , out_InterResultArray = face.Intersect(cable_tray.Location.Curve, out_InterResultArray)
OUT = set_ComparisonResult.ToString(), out_InterResultArray[0].XYZPoint.ToPoint()
Thank you very much! appreciate it ![]()
