I want to select only points that inside the red line.
How can I do?
Amigo @hojukys create a Surface.Bypatch (Your line has to be a closed curve), and use Geometry.DoesIntersect to compare this whit your original list of points, then just filtre and voila, i hope that this work for you!
Hello, Mr. @hojukys
You calculate forces in the slabs with these point meshes
Cordially
christian.stan
thank you!!!![]()
