Hello
I have made mass families and put them together in the shape of a building. I have also created mass floor inside theses masses. From the mass floor I have created surfaces and extracted the perimeter curves, this gives me the “outer” walls of the building. The problem I now facing is getting the inner walls.
Since each apartment is a mass floor, these will create two overlapping lines that will create two walls where there should only be one. Don’t know if I manage to explain this good enough. But if anyone has a suggestion on where to start here, I will be very happy!
Outer walls works
