I am using the design script “1 …10;” to make a list that counts from 1 to 10… Is there a script or syntax that allows for counting from “001 to 010” making it a 3 digit number?
Thanks!
Thanks!
Can the output be a string? If so, the String.PadLeft node can be used to fill in any “missing” zeros on the left side after converting your number to a string.
This blog article has more detail.
You guys rock! THANKS!
Oops! It looks like I and David Replied at the same time
. David your solution is good![]()
