In the FastApi AWS environment, employ custom user authentication
It just concerns best practises here. I’m currently using FastApi from the Python Framework to create an API. I’m deploying this using API Gateway, AWS Lambda, and DynamoDB for storage. I want to add authentication and authorization now that I’ve implemented some CRUD-Operations. The concept is that users can obtain a bearer token by logging in with their username (or email) and password.
Since I don’t use Cognito much, I considered integrating Auth functionality into the FastApi code. (create registration and login endpoints i.e. with fastapi-users library). Does that meet best practises standards? Or are there compelling reasons to employ API-Gateway Authorizers and Cognito for such purposes?
Wrong forums I think. This for the Dynamo platform here:
https://dynamobim.org/
You’ll probably want to post this to an Amazon centric forum where DynamoDB is understood.
