Hello.
The below code is python which is put into a Python node in Grasshopper to send data to Cove.Tool’s REST API endpoint.
import rhinoscriptsyntax as rs
import json, ssl, urllib2
from System.Net import WebRequest
from System.IO import StreamReader
from System.Text import Encoding
class ApiHelpers:
def init(self, token):
self.token = token
def post_request(self, path, data, use_token=True):
url = self._api_url(path)
data = json.dumps(data)
headers = self._headers(use_token)
request = urllib2.Request(url, data=data, headers=headers)
try:
response = urllib2.urlopen(request)
except Exception as e:
try:
result = self.legacy_url_open(url, use_token, data)
return result
print(e)
return {'result': 'error'}
return json.load(response)
def get_request(self, path, use_token=True):
request = urllib2.Request(url, headers=headers)
try:
try:
result = self.legacy_url_open(url, use_token)
return result
print(e)
def legacy_url_open(self, url, use_token, data=None):
request = WebRequest.Create(url)
request.ContentType = "application/json"
if use_token:
request.Headers.Add('Authorization', 'Token ' + self.token)
if data:
request.Method = "POST"
bytes = Encoding.ASCII.GetBytes(data)
request.ContentLength = bytes.Length
request_stream = request.GetRequestStream()
request_stream.Write(bytes, 0, bytes.Length)
request_stream.Close()
response = request.GetResponse()
result = StreamReader(response.GetResponseStream()).ReadToEnd()
return json.loads(result)
def _api_url(self, path):
return 'https://app.covetool.com/api/' + path + '/'
def _headers(self, use_token):
headers = {
"Content-Type": "application/json",
if use_token:
headers['Authorization'] = 'Token ' + self.token
return headers
Execution
helpers = ApiHelpers(token)
unit_system = rs.UnitSystem()
if unit_system == 4:
unit_system = “Unit System: Meters”
si_units = “true”
elif unit_system == 9:
unit_system = “Unit System: Feet”
si_units = “false”
unit_system = “Unit System: Not Meters or Feet”
raise RuntimeError(“Units should be Meters or Feet”)
data = {
‘run’: run,
‘si_units’: si_units,
‘building_height’: building_height,
‘roof_area’: roof_area,
‘floor_area’: floor_area,
‘skylight_area’: skylight_area,
‘wall_area_e’: wall_area_e,
‘wall_area_ne’: wall_area_ne,
‘wall_area_n’: wall_area_n,
‘wall_area_nw’: wall_area_nw,
‘wall_area_w’: wall_area_w,
‘wall_area_sw’: wall_area_sw,
‘wall_area_s’: wall_area_s,
‘wall_area_se’: wall_area_se,
‘window_area_e’: window_area_e,
‘window_area_ne’: window_area_ne,
‘window_area_n’: window_area_n,
‘window_area_nw’: window_area_nw,
‘window_area_w’: window_area_w,
‘window_area_sw’: window_area_sw,
‘window_area_s’: window_area_s,
‘window_area_se’: window_area_se,
result = helpers.post_request(‘run-values’, data)
eui_total = result[‘data’][‘eui_total’]
print(‘EUI Total:’, eui_total)
cooling = 0
heating = 0
lighting = 0
equipment = 0
fans = 0
pumps = 0
hot_water = 0
pv_energy = 0
eui_breakdown = result[‘data’][‘eui_breakdown’]
headers = eui_breakdown[‘headers’]
values = eui_breakdown[‘values’]
for i, header in enumerate(headers):
value = float(values[i])
if header == ‘Cooling’:
cooling = value
print(‘Cooling:’, cooling)
elif header == ‘Heating’:
heating = value
print(‘Heating:’, heating)
elif header == ‘Lighting’:
lighting = value
print(‘Lighting:’, lighting)
elif header == ‘Equipment’:
equipment = value
print(‘Equipment:’, equipment)
elif header == ‘Fans’:
fans = value
print(‘Fans:’, fans)
elif header == ‘Pumps’:
pumps = value
print(‘Pumps:’, pumps)
elif header == ‘Hot Water’:
hot_water = value
print(‘Hot Water:’, hot_water)
elif header == ‘PV Energy’:
pv_energy = value
print(‘PV Energy:’, pv_energy)
WHen, I try to implement in Dynamo I get a warning that JSON cannot be incorporated into the Dynamo python node.
Any suggestions on how to re-write this so that it works in Dynamo?
