ImportInstance.ByGeometry
Hello
I created a surface in dynamo using Surface.ByLoft
I’d like to import this into Revit so I tried using the ImportInstance.ByGeometry node
It works, kind of…
As you can see, the imported geometry is slighly offset from the original surface shown in dynamo
Any idea on how to fix this?
Any help would be much appreciated, thank you in advance
Hello @opb …do you work in revit 2022 ?
hello @sovitek I’m currently in 2021!
update
Turns out the imported geometry’s reference level was off…
When I adjusted the reference level, it fit perfectly
Additional question though, when the import command is executed and the dynamo surface gets converted to revit object, what determines the reference level? also, is there any way for me to assign a reference level?
thank you
