Importing Dynamo components into Revit.
Using Dynamo to create multiple components in Revit, how to create a single family, and use multiple family instances to control parameters instead of creating multiple families.
Could you please explain further, what you are trying to do? DO you want to create multiple instances of a Family and change some instance parameter for each of them?
Thank you for the reply!
I have created many standard models using Dynamo’s Springs.FamilyInstance.ByGeometry, and I want to generate multiple instances under a single family.Now each standard model has its own separate family.
So you want to duplicate the types. This can be done in either in a project or the family editor. Sharing your script and what you’ve tried so far will help.
This is why you’re not getting any answers.
