Import instance wrong scale
As shown in the image the geometry looks correct in the dynamo window, but when i use import.instance.bygeometries it places it in Revit at the wrong scale.
if i manually link in the sat file that is generated, it comes in correctly
Hi @oakleym,
Welcome to the community!
My guess is that it’s a units problem? conversion from imperial perhaps? Does scaling down by 25.4 work?
Hope that helps,
Mark
Hello…try to check your scale for import symbol
I am facing issues with the Transform while importing geometry into the Revit. The X and Y location is correct, but it’s offsetting in the Z direction (Around 215’-8"). Any suggestions?
Any solution so far?
Nope.
