whats wrong in my code ? i want to import a .dwg to a family template
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
cad = IN[0]
view = UnwrapElement(IN[1])
options = DWGImportOptions()
id = clr.StrongBox[ElementId](ElementId(271182))
bool = doc.Import(cad, options, view, id)
OUT = "Done"
Maybe because the file path is not raw? like this ‘C:\path\to\image.jpg’ ?
Maybe this will help. This code is for importing an image, but its in the same method tree:
Imports an Image
TESTED REVIT API: -
Author: Gui Talarico | github.com/gtalarico
This file is shared on www.revitapidocs.com
For more information visit http://github.com/gtalarico/revitapidocs
License: http://github.com/gtalarico/revitapidocs/blob/master/LICENSE.md
# See: http://www.revitapidocs.com/2015/05c3dbe2-fe7e-c293-761d-b11f356a011b.htm
from clr import StrongBox
from Autodesk.Revit.DB import XYZ, ImageImportOptions, BoxPlacement, BuiltInParameter
# Import Options
import_options = ImageImportOptions()
import_options.Placement = BoxPlacement.Center
This file has been truncated. show original
Looks like your method isn’t seeing the element id input. Verify that is returning correctly, as this may be a CPython issue, in particular with the various data types for overloads could be causing a problem here.
Check if that’s constructing correctly.
@leonard.moelders @jacob.small
the import via image or change properties does not work…
i tried to access “StrongBox” … but without success
import sys
cad = IN[0]
#StrongBox[Element]()
id = clr.StrongBox[Element](ElementId(23))
OUT = "Done"
what the hell is a StrongBox ? for what need i an Id ? which Id is it?
Strongbox is a way to refer to a reference of an object in memory which has an explicit type, in this case a Revit element id. You can read more about this method in the documentation page .
The reason for requiring an element ID isn’t clear to me, but it may have been intended as a way to manage DWGs back in the day - allowing API updates more directly. I’d use a value of -1 for now, which is an invalid element ID, as that seems to reset the ID to a new value.
I’m not sure how to reference a strongbox object in CPython, but your original code (with the change to element ID) runs fine in IronPython.
Maybe @Gui_Talarico can explain it further for you as it is his code
Here is the correct syntax with CPython3 engine (PythonNet) for method with ‘out parameters’
import sys
cad = IN[0]
dummyId = ElementId.InvalidElementId
result_import, cad_instance_Id = doc.Import(cad, options, view, dummyId)
OUT = result_import, doc.GetElement(cad_instance_Id)
https://pythonnet.github.io/pythonnet/python.html#out-and-ref-parameters
@c.poupin ,
what does the error mean?
I have never had this error before
If you restart dynamo, this fixes the error ?
@c.poupin ,
i restarted revit also…
but the error changed
importDWG_V01.dyn (8.9 KB)
I don’t know, it’s very strange, maybe try to reinit the Cpython3 engine
I can’t reproduce the bug
@c.poupin ,
i use core 2.13. should i upgrade? which is stable?
I used core 2.13 (Revit 2023) too for this test
Do you have update latest version hotfix 2023 yet?
@chuongmep ,
i did the hotfix! but still not working
i work right now with 2.16
This is Test in my side , also don’t have any problem like that :
But it just is dynamo version 2.13
