Hello Dynamo users!
Meet a noob who is not familiar with possibilities of Dynamo but would like to learn them.
I wonder if Dynamo can create txt-file with user defined property sets for IFC export. In my imagination it should work this way:
- user choose custom parameter that needs to be exported;
- user insert the name of custom property set which will store the parameter;
- script defines if it is a type or instance parameter and write either T or I into txt-file;
- script defines all objects containing this parameter, addresses IFC mapping file and write IFC Class Name for respective elements into the same txt-file
- all text must be written in a certain way. Here is an example
So the main question is: do I have to learn Python for doing all this or I can only use Dynamo and its nodes? And, if the second option is correct, which nodes can help me to achieve my goals?
