The available code for exporting IFC files does not export Revit Property Sets. you can find the code below:
#python nodes in dynamo 0.7
#proposed by Nicklas Verdier Østergaard, nvo@niras.dk
#Based on tools.dwf by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#dataEnteringNode = IN
folder=UnwrapElement(IN[0])
name=UnwrapElement(IN[1])
fileversion = IN[2]
wallandcolumnsplitting = IN[3]
exportbasequantities = IN[4]
#IFCVersion=UnwrapElement(IN[2])
# Start Transaction
options=IFCExportOptions()
#if fileversion != None:
# options.FileVersion = fileversion
if fileversion == "IFC4":
options.FileVersion = IFCVersion.IFC4
if fileversion == "IFC2x2":
options.FileVersion = IFCVersion.IFC2x2
if fileversion == "IFC2x3":
options.FileVersion = IFCVersion.IFC2x3
options.FileVersion = IFCVersion.IFC2x3CV2
if fileversion == "IFCBCA":
options.FileVersion = IFCVersion.IFCBCA
if fileversion == "IFCCOBIE":
options.FileVersion = IFCVersion.IFCCOBIE
if fileversion == "":
options.FileVersion = IFCVersion.Default
options.WallAndColumnSplitting = wallandcolumnsplitting
options.ExportBaseQuantities = exportbasequantities
#IFCVersion Version = (IFCVersion) Enum.Parse( typeof(IFCVersion), UnwrapElement(IN[2]), true );
#x.FileVersion = IFCVersion.IFC2x3CV2
c=doc.Export(folder, name, options)
# End Transaction
OUT="Defult settings used"
OUT=c`
How can I export an IFC file by “Revit Property Sets” using Dynamo?
Sincerely,
Sobhan
