Dynamo Revit IFC export level of detail
I’m want to specify the level of detail of the IFC export with in revit. can someone help me out?
using the following Phyton code:
#python nodes in dynamo 0.7
#proposed by Nicklas Verdier Østergaard, nvo@niras.dk
#Based on tools.dwf by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
#dataEnteringNode = IN
folder=UnwrapElement(IN[0])
name=UnwrapElement(IN[1])
fileversion = IN[2]
wallandcolumnsplitting = IN[3]
exportbasequantities = IN[4]
view = UnwrapElement(IN[5])
#IFCVersion=UnwrapElement(IN[2])
# Start Transaction
total_export = []
for i,v in enumerate(view):
options=IFCExportOptions()
#if fileversion != None:
# options.FileVersion = fileversion
if fileversion == "IFC4":
options.FileVersion = IFCVersion.IFC4
if fileversion == "IFC2x2":
options.FileVersion = IFCVersion.IFC2x2
if fileversion == "IFC2x3":
options.FileVersion = IFCVersion.IFC2x3
options.FileVersion = IFCVersion.IFC2x3CV2
if fileversion == "IFCBCA":
options.FileVersion = IFCVersion.IFCBCA
if fileversion == "IFCCOBIE":
options.FileVersion = IFCVersion.IFCCOBIE
if fileversion == "":
options.FileVersion = IFCVersion.Default
options.WallAndColumnSplitting = wallandcolumnsplitting
options.ExportBaseQuantities = exportbasequantities
options.FilterViewId = v.Id
options.AddOption("UseActiveViewGeometry", "true");
options.AddOption("TessellationLevelOfDetail", "1");
#IFCVersion Version = (IFCVersion) Enum.Parse( typeof(IFCVersion), UnwrapElement(IN[2]), true );
#x.FileVersion = IFCVersion.IFC2x3CV2
c=doc.Export(folder, name[i], options)
total_export.append(c)
# End Transaction
OUT="Default settings used"
OUT=total_export
As you can see I tried adding the “TessellationLevelOfDetail”, but that doesnt seem to work as my file size isnt getting anything less.
Thanks in advance!
Greetings, Guido
its working now. post can be removed.
Hi @g.honders,
Maybe you tell how you solved it and share the code that is working, so others can also benefit from it.
Kind regards,
Mark
adding the following code to the phyton script (as above):
options.AddOption(“TessellationLevelOfDetail”, “1”);
filling in a value from 0 to 4. with 0 being extra low.
Cheers!
