does anyone have an idea how to adjust the classification settings in the IFC batch export custom nodes or Python script ?
it worked using:
options.AddOption(âClassificationNameâ,âxâ)
options.AddOption(âClassificationFieldNameâ,âxâ)
Hey,
Iâm not fluent in Python. Could you please explain how to implement this option to be able to adjust classification for IFC export?
Hi @piotr.bocian,
Maybe this topic can point you in the right direction.
https://forum.dynamobim.com/t/export-a-model-using-different-sites/91208/6?u=mjb-online
which python code are you using?
it has to be added to the lines where the other options are.
Iâm using node from Genius Loci, it has python script as follows:
#Based on a Nicklas Verdier Ăstergaard's script, nvo@niras.dk
#https://github.com/Autodesk/revit-ifc/tree/2810c479e27819da97656759a1dda28cbdde0538/Source
#Revised by Alban de Chasteigner
# Import RevitAPI
clr.AddReference("RevitAPI")
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
app = uiapp.Application
folder=UnwrapElement(IN[0])
view = tolist(UnwrapElement(IN[1]))
name=tolist(UnwrapElement(IN[2]))
fileversion = IN[3]
Projectorigin = IN[4]
inputPhase = UnwrapElement(IN[5])
userDefinedPset = IN[6]
revitInternalPset = IN[7]
wallandcolumnsplitting = IN[8]
exportbasequantities = IN[9]
if inputPhase != None:
phaseString=str(inputPhase.Id)
pass
if userDefinedPset != "":
userDefPsetBool= "true"
userDefPsetBool= "false"
if revitInternalPset ==True:
revitInternalPset= "true"
revitInternalPset= "false"
result = []
for i,v in enumerate(view):
options=IFCExportOptions()
#if fileversion != None:
# options.FileVersion = fileversion
if fileversion == "IFC4":
options.FileVersion = IFCVersion.IFC4
if fileversion == "IFC2x2":
options.FileVersion = IFCVersion.IFC2x2
if fileversion == "IFC2x3":
options.FileVersion = IFCVersion.IFC2x3
options.FileVersion = IFCVersion.IFC2x3CV2
if fileversion == "IFCBCA":
options.FileVersion = IFCVersion.IFCBCA
if fileversion == "IFCCOBIE":
options.FileVersion = IFCVersion.IFCCOBIE
if fileversion == "":
options.FileVersion = IFCVersion.Default
options.WallAndColumnSplitting = wallandcolumnsplitting
options.ExportBaseQuantities = exportbasequantities
options.FilterViewId = v.Id
options.AddOption("ExportInternalRevitPropertySets",revitInternalPset)
options.AddOption("ExportIFCCommonPropertySets","true")
options.AddOption("ExportAnnotations ","true")
options.AddOption("SpaceBoundaries ", "0")
options.AddOption("ExportRoomsInView", "false")
options.AddOption("Use2DRoomBoundaryForVolume ", "true")
options.AddOption("UseFamilyAndTypeNameForReference ", "true")
options.AddOption("Export2DElements", "false")
options.AddOption("ExportPartsAsBuildingElements", "false")
options.AddOption("ExportBoundingBox", "false")
options.AddOption("ExportSolidModelRep", "true")
options.AddOption("ExportSchedulesAsPsets", "false")
options.AddOption("ExportSpecificSchedules", "false")
#True doesn't work. It would be necessary to use OpenInBackground method.
options.AddOption("ExportLinkedFiles", "false")
options.AddOption("IncludeSiteElevation","true")
options.AddOption("StoreIFCGUID", "true")
options.AddOption("VisibleElementsOfCurrentView ", "true")
options.AddOption("UseActiveViewGeometry", "true")
options.AddOption("TessellationLevelOfDetail", "0,5")
options.AddOption("ExportUserDefinedPsets",userDefPsetBool)
options.AddOption("ExportUserDefinedPsetsFileName",userDefinedPset)
pass
options.AddOption("ActivePhase", phaseString)
pass
options.AddOption("SitePlacement", IN[4])
# options.AddOption("ClassificationName","x")
# options.AddOption("ClassificationFieldName","x")
c=doc.Export(folder, name[i], options)
result.append(c)
# End Transaction
OUT="Default settings used"
OUT='Success'
But donât know how to add the option.
they are in the code but disabled. i have adjusted the script you only need to all two inputs to the python node (10: Classification Name) and (11: Classification Field Name) and use the following code:
# Import RevitAPI
def tolist(obj1):
else: return [obj1]
fileversion = IN[3]
clN = IN[10]
clFN = IN[11]
pass
result = []
pass
pass
options.AddOption("ClassificationAltName",clN)
options.AddOption("ClassificationFieldName",clFN)
result.append(c)
# End Transaction
OUT='Success'
Replaced Python code with yours @Mohamad_Kayali and modified node as on picture, but it doesnât export classification
i have edited the code will you try again to copy it and run your script?
and remember outside the node you need to provide string inputs
does the parameter in revit called test2 and does it contain values?
otherwise please upload the revit file with the dynamo script youâre using.
No, there is no parameter called test2. Itâs just string for testing purpose. What type of data does it expect? Isnât it string?
correct it is a string but the string should be the name of a revit parameter. the script will export the value of that parameter under certain name (test1). the name can be anything but the classification field name not. so now if you make a project parameter in revit and add a value to that parameter (for example âxâ). you will get in the ifc viewer (test1 : âxâ )
Tried to do so, but still doesnât work
correct, i have tried to fix them but theyâre not working!
@Alban_de_Chasteigner do you have any idea how to solve it?
