If true add a string at then end of item
Hi all!
This is my first post about Python as I am starting my learning path through this programming language!
I could not see any learning resource on the internet which is focused on Python sessions applied in Dynamo so I will have to look into many websites in order to learn the basics and then apply them into Dynamo environment.
Here I post a screenshot with the issue I am behind.
As you can see, I would like to add at the end of the input list of strings IN[0] the word ‘_CONTROL’ if the IN[1] input is true.
Thank you so much.
@JMCiller ,
actually you are doing this already… …where do you want to store the value?
I would like to get just one list with the proper values as I already did with Dynamo nodes:
Hi @JMCiller ,
See if something like this works for you:
values = IN[0]
conditions = IN[1]
OUT = []
i = 0
while i < len(values):
    if conditions[i]:
        OUT.append(values[i]+"_CONTROL")
        OUT.append(values[i])
    i = i + 1
PS: I am by no means any good in Python, if anyone has some suggestions to improve and/or simplify this, please don’t hesitate :slight_smile:
@JMCiller the statement you are using in your conditional if is a string, you should use a valid boolean(True in Python, true in DS), plus to make it work properly you couple the inputs of the lists items with the bools items using a zip function;
The second approach is a comprehension list, worth looking at if you are planning to learn Python:
Very nice! Thanks for sharing! I even got it to work with only 1 line based of your approach :smiley:
OUT = [x + "_CONTROL" if y == True else x for x,y in zip(IN[0],IN[1])]
