Hello dear community,
I have a nested list inside dynamo, something like image attached. I am struggling finding a way to add string “LF” at the end of list of string. There should be condition embeded in this operation: add string only if existing string in the nested list is ending with " symbol. Do you have any suggestion what is the easiest way to achieve this? I have to keep the list structure of the original list. Also, condition should be checked only for @1 level, no need to go across all list levels.
Thank you
A loop in Python is the only way I can think of…
GPT just wrote this…so I haven’t tested it… but it should give you a start
def add_lf_to_nested_list_items(nested_list):
for i in range(len(nested_list)):
if isinstance(nested_list[i], list): # If the item is a list, recurse
add_lf_to_nested_list_items(nested_list[i])
elif isinstance(nested_list[i], str) and nested_list[i].endswith('!'): # Modify the condition as needed
nested_list[i] += "LF" # Add "LF" to the item that meets the condition
# Example usage
nested_list = ["Hello!", "World", ["Test!", "Example", ["Another Test!"]]]
print(nested_list)
Obvs you feed in your nested list instead of using the Hello World one ![]()
and change print to OUT =
Isn’t it possible to filter the Elements first you want to add ‘LF’ to at the end of the string?
little variant with a recursive function
import sys
def add_end_symbol(value, end_char = "!", add_str="LF"):
return value + add_str if value.endswith(end_char) else value
def nestedRecursFunc(lst, functoApply):
newlst = list(lst)[:] # copy input list and convert it (if necessary)
for idx, elem in enumerate(lst):
if isinstance(elem, list) and len(elem) > 0:
newlst[idx] = nestedRecursFunc(lst[idx], functoApply)
elif isinstance(elem, list) and len(elem) == 0:
newlst[idx] = []
newlst[idx] = functoApply(lst[idx])
return newlst
multi_NestedList = IN[0]
OUT = nestedRecursFunc(multi_NestedList, add_end_symbol)
Thank you guys for helping out, I tested the python solution and it works as expected, thank you for sharing that.
I’ve also tested solution provided by Nick and marked that as solution as well. in case someone wants to do it just using dynamo. Actually, simple addition node works much better than all other string functions like concat which i’ve tried to use
