Any idea why the if return as True no matter what the test result is?
Thanks Vikram,
So I’ve tried to overcome this by passing a list with my points as sub-lists but still no good!?
Your test list is not as long as the lists fed into true and false
Let me try to explain this. Consider you have…
A list (A) of 5 points fed into the true port
Another list (B) of 5 points fed into the false port
Then you will need a list of 5 booleans to be fed into the test port
If the boolean list is {true,true,true,false,false}
Then the resulting list will be a list comprising of the first 3 elements from list (A) and the next 2 elements from list (B)
I think I understood that, therefore I did create a single lists fed into the true and false but it seems that it is still recognizes the length of the sub-lists as not equal!
In your case you can introduce a List.Create node
Thanks Vikram, I twisted my mind differently and it worked!
My case was that I need to reduce the number of a curve point, which is given and I don’t know how many, by removing even indices but keeping the last item if the total count is even!
I don’t know if this this the best solution but it worked.
The If node works in an extremely specific (and sometimes very annoying) way. As Vikram tried to explain, it works on a single object level.
If you feed in lists of different length, the logic behind it breaks down and the result is limited to the shortest list. If you’re trying to work on a list level and are trying to pass lists of varying length, you might be better served by a python node or an imperative function.
Thanks you guys for helping!
Unfortunately I don’t know much either python or imperative functions! however I tried the imperative code block method and it worked although I managed to use the IF node but at a later stage where I pass single curve products out of my two points lists.
You could also try the scopeif-node, but that node has it’s limitations too. Looks like they are looking into this: https://github.com/DynamoDS/Dynamo/issues/6258
