"If" node doesn't output an array of values
The problem probably has to do with how if node works on different length lists for the true and false values. The common alternative is ScopeIf but it can be a bit trickier.
I don’t remember the exact details but I am sure there are several posts somewhere comparing the two. Some older examples include IF node and If and Lists of different lengths
