I’ve got a pretty involved graph that I want to take one action if it runs in 2016 and different action if it’s in 2017.
My problem is that there are several parts the run in both, and there’s no clear division I can see to pipe into an IF node.
I’ve been dealing with it by Freezing one node and Unfreezing the other depending on which version of Revit I’m in.
Those are the purple and blue Groups in the center.
I know how to find the Revit version, I just don’t know how I can split up my graph based on the results.
The first part of this Graph runs under 2016 and compares its Text elements the 2016 upgraded version.
It examines the height of the Text Boxes and automatically widens the Text Box a little bit (~6%) if the text wrapped onto an additional line.
I’d like to share this with the community, but I’d like it to run without tweaking for both versions.
Any suggestions on how I can branch in the middle? As you can see, there are wires that both branches need on both sides of the branch.
