Identifying and Removing Duplicate Lines in a List
Hi everyone,
I’d like to filter out duplicate lines from a list along with their counterparts. I’ve managed to extract one member of each pair, effectively eliminating the duplication. Now, I also want to remove the other member of the pair from the list of lines. To achieve this, I intend to find the indices of the duplicate lines in the original list based on the list of duplicates, but I’m getting ‘-1’ for everything. What could be the solution to this problem?
List.SetDifference also didn’t work. It didn’t take out any elements, but I can see both two are the same(start.p, end.p, vector, length).
I can’t understand your objective well. Could you share the Dynamo file?
Have you tried using List.UniqueItems?
Building.dyn (104.4 KB)
fh_alap.dwg (747.8 KB)
REVIT_ép.rvt (5.4 MB)
List.UniqueItems output the same list as the original.
Like this?
Geometry objects don’t compare well as there are inherent rounding issues. You’ll want to convert them to something comparable (like a string) in order to check for matching indices.
Or this:
