Good morning everyone.
I have the following problem, I have obtained the warning IDs of my document and I want to export them to Excel but that data is not exported, Excel opens but the data is not displayed, why???
clr.AddReference('RevitAPI')
import Autodesk.Revit.DB.Structure as DBS
from Autodesk.Revit.DB import BuiltInCategory
from Autodesk.Revit.UI.Selection import *
link_instances = FilteredElementCollector(doc).OfClass(RevitLinkInstance).ToElements()
def aplanar_lista(lista):
resultado = []
for item in lista:
if isinstance(item, list):
resultado.extend(aplanar_lista(item))
resultado.append(item)
return resultado
ColectorWarning = doc.GetWarnings()
IdElem_Warning = []
Cantidad_Warning = []
for w in ColectorWarning:
elem = w.GetFailingElements()
dato = []
for e in elem:
valor = str(e.IntegerValue)
dato.append(valor)
elem_aplan = aplanar_lista(elem)
concatenado = " y ".join(map(str, elem_aplan))
IdElem_Warning.append(concatenado)
Cantidad_Warning.append(len(elem))
OUT = IdElem_Warning
problemas_warning.dyn (10.9 KB)
