i cant follow you … text notes itself? or these are tags you want change a value?
can you explan more ?
KR
Andreas
its like TT command in AutoCAD using autolisp
I don’t know this command, can you show the before and after?
Is this in Revit or Civil 3D?
If Revit, this node will help: Dynamo Dictionary
Use it on the nodes you want to change the values of.
To get the value you want to set, there is a sister node to get the text value.
revit
Hola amigo @vikas.kpoojary buenas. did you try Find / Replace? just select your text notes, put in the search : * and in replace the desire value, i belive that could work!
YA BUT IT WILL REPLACE ALL , BUT INEED SELECTED ONE
Can you try set the lacing to longest on the settext node?
its not working
