I can’t find the dynamo icon in revit - manage ( Can you help me )
Obvious question first: Do you have it installed for 2019? Have you tried reinstalling it?
I have problem in file path may be ?
I downloaded it put I don’t know its right path to connect with revit 2019
Are you sure you’re installing Dynamo for Revit? The installer should ask which versions of Revit you’re installing for and automatically put them in the right place.
can you send me link for Dynamo for Revit may be I setup wrong version .
The Download page should explain and link to everything you need.
The one next to it that says Revit. It explains the different versioning and has a link to the downloadable builds (which I believe are also at the bottom of the page.)
