Viewport labels? I am not sure I know what that is, but I will make a guess that you are asking about turning off the Viewport Titles:
If that’s indeed the case, then the easiest way would be to make a Viewport Type that hides the title. For example:
Once you have that ready, you would want to change the Viewport Type for the selected Viewports like this:
Python code:
# Copyright(c) 2019, Konrad K Sobon
clr.AddReference("RevitAPI")
sys.path.append(pyt_path)
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessListArg(_func, _list, _arg):
return map( lambda x: ProcessListArg(_func, x, _arg) if type(x)==list else _func(x, _arg), _list )
def Unwrap(item):
return UnwrapElement(item)
def ChangeViewportType(vp, newVp):
vp.ChangeTypeId(newVp.Id)
return vp
if isinstance(IN[0], list):
viewports = ProcessList(Unwrap, IN[0])
viewports = [Unwrap(IN[0])]
vpName = IN[1]
try:
errorReport = None
allVp = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Viewports).ToElements()
validTypeIds = allVp[0].GetValidTypes()
validTypes = []
for i in validTypeIds:
validTypes.append(doc.GetElement(i))
selectedVp = next((x for x in validTypes if x.ToDSType(True).Name == vpName), None)
output = ProcessListArg(ChangeViewportType, viewports, selectedVp)
except:
import traceback
if errorReport == None:
OUT = output
OUT = errorReport
Hope this helps.
Cheers!
