How to turn off Viewport Titles?
Hey,
So I want to auto turn off viewport labels…
I’m really struggling to get hold of the built in parameter values, I’m trying a few different nodes, but they just aren’t giving values… I can see that they exist, but no values!
Would anyone be able to help me understand why?
Thanks,
Mark
Viewport Title.dyn (24.4 KB)
test1.rvt (1.3 MB)
Viewport labels? I am not sure I know what that is, but I will make a guess that you are asking about turning off the Viewport Titles:
If that’s indeed the case, then the easiest way would be to make a Viewport Type that hides the title. For example:
Once you have that ready, you would want to change the Viewport Type for the selected Viewports like this:
Python code:
# Copyright(c) 2019, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
def ProcessList(_func, _list):
    return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessListArg(_func, _list, _arg):
    return map( lambda x: ProcessListArg(_func, x, _arg) if type(x)==list else _func(x, _arg), _list )
def Unwrap(item):
	return UnwrapElement(item)
def ChangeViewportType(vp, newVp):
	vp.ChangeTypeId(newVp.Id)
	return vp
if isinstance(IN[0], list):
	viewports = ProcessList(Unwrap, IN[0])
	viewports = [Unwrap(IN[0])]
vpName = IN[1]
try:
	errorReport = None
	allVp = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Viewports).ToElements()
	validTypeIds = allVp[0].GetValidTypes()
	validTypes = []
	for i in validTypeIds:
		validTypes.append(doc.GetElement(i))
	selectedVp = next((x for x in validTypes if x.ToDSType(True).Name == vpName), None)
	output = ProcessListArg(ChangeViewportType, viewports, selectedVp)
except:
	import traceback
	errorReport = traceback.format_exc()
if errorReport == None:
	OUT = output
	OUT = errorReport
Hope this helps.
Cheers!
@Konrad_K_Sobon you are the man.
Thank you for your time and expertise.
Cheers,
Mark
Hello, I am trying to switch off viewports title in legend. Somehow it does not want to work. It only switches titles of sheet views but not for legends??? :frowning_face:
Thanks a lot
Is the Sheets.Viewports node giving you the legends?
No, but I have found an intermediate solution. When sheets are still empty and only legends are placed, it works perfectly.
You’re awesome! Thank you
